WSCC F1 Fantasy Is Here! Γ—
Wanted: set of carpets in black for SEiW
wanted a full set of carpets for SEiW - in black or black & yellow trim - either new or in very good condition or if anyone has a supplier that can help. TIA Phil R
Not 100% sure as I never bothered with carpets, but might need to say what width tunnel you have as that varied over the years πŸ‘
Β
You do. There are different chassis for different gearboxes, so a Type 9 chassis has a narrow tunnel and wide footwells, while an MT75 chassis has a wider tunnel and one wide, one narrow footwell and SEiGHT and Mega S2000/Sport 250 chassis, (though not the same), have even wider tunnels and two narrow footwells.
Β
This width variation hits pretty much every piece in the carpet set, too, rear bulkhead included.
And you might have a type 9 box in the mt75 chassis - so can’t go on that 🀣
Thanks all for the steers above - I’m going to try to get a set made to the existing samples - at least they should then fit - but may be a winter 25/26 project now for both cost & timing πŸ™πŸ‘
Γ—
Γ—
