I've done a bit of karting in the past, mainly doing historic demos. I have always like the idea of doing Sprints and Hillclimbs as you are the only car on track.
I understand I could enter my Westfield in the road going class but wondered what sort of cage would be required if any other than the standard Westfield roll hoop and would I need to fit 4 point harnesses rather then the 3 points it currently has.
Although a standard road car with a roof doesn't require either I seem to remember reading something about open top kit cars but not sure where.
Is this a thing or did I imagine it ?
Hi Steve,
It should be quite straightforward, you do not need a roll cage in roadgoing class, a braced Roll Hoop is required from a safety point of view. Similarly you could compete with a 3 point harness, but a 4 point is generally considered safer and also allows better control of the car as you are firmly held in your seat.
To check the latest regulations from Motorsport UK, see here Latest NCR's  scroll to the bottom of the page and press link. All the links are being embeded to help navigation. You want Chapter 14 Sprints & Hillclimbs.
Hi Nick, thank for explaining.
The bar I have has got a diagonal bar fitted but I don't know what sort of spec it is. The belts I have look like a 4 point harness but have a single top fixing. The chassis I have was made like this so I would have to fit extra mounts to fi a proper 4 point harness.
If I fitted a better cage, say a current caged one would the car still be classed as a road car ?
I started reading the regs and remember why I thought to ask on here first !
I wasn't sure a Westfield actually classed as a standard road car but they fit in the Road Cars - Specialist Production Cars category.
Thanks for the link to the regs I will have a read. A friend sent a link saying there were some spaces available at Gurston Driving school and it got me thinking.
Yes you can still enter as road going if you have a full cage, it's just extra safety and as to your harnesses it would be to big a job to get the extra bosses welded into the chassis box section.
Just read the bit about a cage can be fitted as long as it doesn't pick up suspension mounting points. Perhaps I need to keep a look out for a better roll hoop. Thanks.
Steve,
Your not far away so come to Gurston hill climb next weekend, there will be a variety of Westfields there and also the MSA scrutineers who are very helpful.
Dave
What you have as a roll hoop looks like it would pass. @Smudge62 (Dave's) suggestion of going to Gurston is a really good idea. You will have a much better understanding after that visit. Also attending their School is a great way to further understand what this sport is all about.
Hope that helps.
Thanks for the replies. I'm planning to come and watch next weekend. I always plan to attend more often but never seem to get a chance.
It will be good to see you there.  My westfield is more or less bog standard so you can see what is required with respect to rules.  Double spring on throttle,  wheel studs thread showing on wheel nuts , yellow tape on battery earth, little sticker showing off direction for ignition key, yellow tape or sticker showing tow point front and rear, timing strut, mot, tax, insurance and number plates. Roll hoop with bracing as minimum,  height of hoop must be such that line from top of engine to hoop top would go over your head and your head can't touch the hoop.  Hoop has to be specific diameter and thickness and welded.  Seat belts have to pass mot.
Thanks. I seem to remember some of that from looking before, didn't know about wheel studs. The ones it has aren't that long so would probably need changing. The original roll hoop is more show cage quality so that might be an issue. I'm not overly keen on it for road use but there aren't many options.
@Steve G.
I did the Gurston School a few years back and can thoroughly recommend it. As long as the car is road legal and MOT'd, you are good to go, and it gives you a VERY good idea of whats involved, plus VERY good value, as the amount of runs you potentially get in the day is probably more than you would get as a competitor over a whole weekend of racing!
Limited runs is the only downside really.  I watched at Gurston and I think the quickest drivers got 4 runs in total.  I'd like to take the Westfield to the driving school but it isn't running very well at the moment. The alternative would be my Volvo 940 or our newish Corsa, both fun but not ideal really.
The school is great if you like cars in general - when I went at least, there was a wide variety from a sunbeam lotus and Ford Anglia - both with full cages etc, a caterham, another westfield, a few almost brand new gt3 rs's (I kid you not) a Ferrari and a brand new F type jag to name a few.....
Very very informal, but very well set up and run, and IIRC I got about 12 runs in during the day....
Mart.
