RickyG512 Posted Saturday at 10:27 Posted Saturday at 10:27 Here for sale is my beloved V8. I bought this off the son of the owner of JE Developments (Rover V8 specialist John Eales). As you can imagine with the power to weight ratio, it's an absolute beast. I bought the car being around 60% done and since then I've invested another £8,000 in work to get it to a 100% complete and finished and fully working Seight with of course no expense spared. I only ever used Valvoline VR1 Racing 20w-50 which is meant to be the highest rated oil for Rover V8s. I currently have 4x 5L tubs on me which are included in the sale which alone is worth £160. The beast was a little on the hot side so I took it to Mulfab, the completely redesigned the front end, they managed to get the rad closer to the engine, which means it could be much taller and wider, fitted a performance 48mm thick rad, fitted a high flow Davies Craig 14" High Power fan and had it relocated to the rear of the rad where it should be so the front gets clean air. Removed the oil cooler and replaced it with a oil/coolant heat exchanger. A Davies Craig Electronic Water Pump was also fitted. The Davies Craig Electronic Water Pump has the new revised digital control module which is the little TV screen in the cab. After throwing £2,500 at the cooling system, it now runs at 80-85 degrees and always runs 5- 10 degrees below target temp that's set on the controller, which essentially means the car runs without the need of the fan or the waterpump spinning at full speed. I've even had the target temp bumped upto 95 degrees to help it get warm and it would run at 85. In 35 degrees it would run at target temp and not go over, so if target set to 85 it would run at 85. So the cooling system is more than efficient with headroom to spare. I've also treated any surface rust in the rear boot bay area and front suspension area. The ultimate star of the show is the engine from JE Developments, it produces around 330 BHP and goes as well as it sounds (especially after it's been camed. It's also colour matched to the car! I also fitted a LSD to improve handling and stop 1 wheel burnouts when casually moving off from gravel. Also has loads of carbon fibre, such as: Carbon wing mirror Carbon cycle wings Carbon rear numberplate surround Carbon tail light surrounds Carbon door sills Carbon foot sills List of extra loose parts included in the sale which also total high value include: Brand new sealed 2x Chrome exhaust covers (dotted holes) Brand new sealed SoftBits half hood Brand new sealed Westfield Gear knob Door Side screens Door Wind Deflectors SoftBits Tunnel Bag (touring version) Screen channel Cycle wings in BMW Le Mans blue Rear wheel/tyre holder 4 tubs of Valvoline VR1 Racing oil Rear carbon number plate Rear open differential Racetech oil pressure gauge Mocal oil cooler 4x shocks Front brake calipers Fuel pressure regulator BMW paint touch up kit Filler cap Roll bar 5x Team Dynamics wheels in BMW Carbon Black Front lower and upper wishbones Leather style arm rests SPAL high power fan Various light fittings Many of these parts aren't even available anymore. This list doesn't include parts I've fitted to the car, just the extras loose parts included. Below is an extract from the original advertisement which contains further key information "Here is my 1998 Seight which has been completely upgraded since I bought it in 2015. I’ve always loved V8s (my Dad was Factory Manager at JE Engineering) and seeing the development Seight at the JE workshop meant when I decided to buy a Westfield it had to have a sorted John Eales V8 heart. So I’ll start with the JE Developement engine in this car - it is a 4420cc V8 on 48mm down draught Dellorto carburettors, a 234 cam with Vernier timing gear and high rev lifters. The Compression ratio is 10.1 : 1, 44mm inlet valves 38mm exhaust. It produced 320bhp / 296ft on JE Development dyno as a fresh build, its loosened since (done 2k miles) - in short it’s delivers epic performance with all the drama and sound you would expect. It has recently been given a new AP racing green clutch plate, cover and new release bearing fitted <100 miles ago. I upgraded the front brakes to Hi Spec 4 pot callipers, vented discs & hoses / Mintex pads so it has extra stopping power too. Fred Davis of Tracksport built me some fully rose jointed wide track wishbones, in his view they were better then the Westfield items I’d asked him to fit when he set up the suspension - new springs, dampers & bushes all round. It’s had new RaceTech gauges - engine temp, oil pressure, fuel sender, tacho & speedo. Had a starter button and battery cut off fitted with the electrical work done by JE’s son in law who is at Merc F1. I had the car fully resprayed in BMW Le mans blue and bought new Image Wheels “RM2” with Graphite centres, polished & ceramic outer chrome bolts with R888 - Front 7.5 x 16, Rear 8 x 16 Fitted new Interior - side panels, mats, tunnel and back panels and added more comfortable seats. New - Dominator headlamps with LED bulbs, LED indicators, LED brake units, fog and reverse lights. Varley Red top 30 battery, headlight brackets, carbon fibre mirror covers, alloy Windscreen, carbon effect cycle wings & new brackets, chrome roll bar. Overall I’ve upgraded this car without thinking about the cost of anything as I wanted it to look as good as it goes, there is a full folder of paperwork detailing what has gone into it over the last 6 years. (this folder has been carefully hidden away from the missus to disguise my upgraditus habit) I’ve only ever used this car in dry weather, it could easily become a devastating track weapon with the competition spec engine or remain the epic sunny day blast. Car will keep the descriptive reg plate a 4 litre v8 (A4 LVB). To confirm this is a proper Seight chassis so therefore has the reinforced fillet bracing. These have been checked, especially around the rear diff given the high power and torque of the set up - happy to report all is good and chassis is sound. This car is as solid underneath as it shiny on top. The spare wheels are painted in BMW Carbon Black, they are Team Dynamics Qualifyers - 7.5 x 16. The PCD 4 x 108 and have offset ET37 205/45/16 tyres on front 225/45/16 on rear" The previous owner kept a very detailed log of all work carried out, receipts and invoices, drawings, diagrams and dyno charts dating all the way back to the 90s. It's a huge folder which will take time to go through and there is also an excel spreadsheet detailing all the parts he bought that totals to over £45,000. For example just the wheels where just under £2,000. Adding the £8,000 I've spent takes it over £50k In terms of what I've done in my ownership, I have carried out the following work: The Seight owes me around £27k, but I'm willing to list it for £21,995 with all the extra loose parts included. Will sell for £19,995 without the extra parts Please see all the pictures attached 8
