Malcolm P Price Posted March 18, 2025 Posted March 18, 2025 A Salisbury limited slip differential used in a Talbot Sunbeam (which has the same axle as a Hillman Avenger) In good condition Can also be used in axles with these dimensions 8 bolt fixing crown wheel with a 102 mm diameter bore Carrier bearings 65 mm diameter. Distance over carrier bearings 135 mm £280 plus £12 carrage Send any questions to malcoopp@yahoo.com Mal
