Any MG Midget based early Westfield Sevens still out there?
Hi
Are there any very early Westfield Sevens still out there with BMC/BLMC/BL A Series engines, gearboxes and rear axles from Austin Healey Sprites/MG Midgets?
Mike
I can't speak for the sevens, but there's plenty of XIs out there that are Midget based. A lot of them run a type 9 gearbox though.
Is there anything in particular you need to know or are looking for?
Hi, I was just curious to see if any have survived. As an AH Sprite owner and former Mini owner I have a fondness for A Series engines and various spares. A restoration project of such an early Seven would be great.
  • 2 weeks later...
I believe I have 1 that I'm currently restoring
Im looking for the original instruction for the car but I'm struggling to find any online
This is a available in the download area- but you need to be a full member to access.
  • 3 months later...
Sorry for the long reply the document show isn't for my car I'm still trying to identify which model it is any help would be lovely 20250401_094618.thumb.jpg.48577231e534da04c1bc06517cdb60a4.jpg
That can only be one of 132 made Westfield Seven, the first model produced by Westfield. Not sure any document exists for such car...
it’s a very very early, Westfield Seven, and one of the earliest they produced, likely around 1985.
Most of the early cars adopted Ford components but the earliest instead used BMC running gear. The bubble rear arches I’ve only ever seen on one other Westfield before as all the later cars had the square arches fitted.
quite a find :cool:
Classic and Sports car 1985
Similar to yours but with a Coventry Climax.
D
Thanks guy the other questions would be where are they stamped with there number I found a few plates with numbers but I think it jb w7 28 but there is a proper westfield plate
Responded to your PM with some info on that front.
