Posted (edited)
Due to lack of use and a bad back I’ve decided to put my Westfield up for sale.
Registered August 2004 £Offers due to chassis number anomaly.
Owned by myself since January 2012
2 previous owners before me. The guy who built it then a chap called Perksy who is well known on the Kit Car scene
The car has covered 10800 miles and there is a large ring binder with all the build details and receipts totalling over £20000
It weighs approximately 560kg
SBD 225 kit giving 225BHP which was confirmed by a recent comprehensive service and rolling road session at Northampton Motorsport by Troy
SBD taper DTH throttle bodies
MBE 967 ECU
Saab Turbo ‘Red’ injectors
87mm Omega high compression pistons
Steel con rods
Coscast cylinder head
Cometic steel layered head gasket
ARP head stud kit
SBD spec Kent camshafts, springs, caps and platforms
SBD vernier cam pulleys
SBD lightweight small alternator
SBD high exit 4-1 exhaust manifold
SBD 7”x26” repackable silencer (Acoustafil Competition Packing)
SBD heavy duty clutch plate
SBD heavy duty clutch cover
SBD lightened standard flywheel
SBD (Pace) dry sump
BGH Geartech type 9 gearbox with long 1st gear (2.66)
3.92 Ford viscous LSD
Carbon Caterham airbox
Fluke motorsport carbon fibre boot cover
SPA carbon wing mirrors
Carbon fibre footwell cover
Odyssey PC680 lightweight battery
RAC type roll bar
Momo detachable suede steering wheel
Westfield wide track suspension with Procomp dampers and springs
Willans 4” four point safety harnesses
GRP seats
Playskool carbon fibre dash
VDO gauges for fuel, oil pressure, oil temperature and coolant temperature
LED shift light and LED low oil pressure warning light
An accident in February 2015 required a chassis repair resulting in a decision to replace the whole chassis along with nose cone, bonnet and manifold
Enquiries and more photos call or email Pete on 07956 268545 Pete.adshead@hotmail.co.uk
Thanks for reading
Edited by Pete A
Price reduction
  • Like 4
Stunning car, good luck with the sale 👍🏻
Is the car cat’d?
Regards
Dave
Insurance paid me out and I bought it back as the engine was too good to let go. Whole chassis was replaced. Hope this helps
Thanks Pete, so is it cat c or d?
I’ll run the plate on Monday and see what comes back. I’ll will post the results 👍
It takes 1 minutes  to run a txt check to 83600 with the reg number
Cheers Rednop
Thanks for finding that out Pete, I did text you this morning and you got back to me so maybe catch up next weekend.
regards
Dave
Price reduction to £10495 ono
It’s a shame if the cat marker puts people off. It’s a kit car, and new chassis and bodywork means it’s literally as good as new with a cracking spec. If I was in the market for one I would snap it up!
Yeah it had a new chassis so was effectively started again. The engine alone is probably £8K looking at the SBD website
  • Like 4
I am amazed this has not sold yet. Fab engine, top notch spec and cheap enough.
I'm guessing Cat C may put some people off but given the nature of kit cars and how many times they get built, rebuilt, modified and messed about with etc, a car with a new chassic, nosecone, bonnet, high spec and also great wheels is a good way to go IMHO, undoubtedly better than some/many cars that are not Cat C.
10 hours ago, Rednop1 said:
This is a great car great spec it should sell no problems have you tried listing it on some of the well known selling sites that have a much greater foot fall than here ?
Yeah I think Pistonheads is worth a shot
