Sold - Westfield zetec cast Alu sump
Sold.
Westfield supplied cast aluminium sump.
comes with baffle plate & oil pick up pipe
this uses a normal silver top sump gasket
fits both silvertop & blacktop engines
its been on my car for 13k miles. Works well. No leaks etc
£200 collected from south Sheffield. Postage at cost
Just to point out that if fitting to a Blacktop, you’d need a silvertop windage tray (and bolts) as the Blacktop sump has one built in, whereas the silvertop uses a separate bolt on item. 👍
Thanks for the info, But that’s not how it was fitted to mine. It came from the factory with no silvertop windage tray. Just as is. Bolted up to a blacktop factory crate engine.
Interesting… I always wondered if the windage tray was strictly necessary and did fit one to my blacktop when using a Scholar sump of similar design.
Probably advisable if you’re tracking the car allot. No issues with this blacktop without a windage tray in 13k road miles
  • mark-one changed the title to Sold - Westfield zetec cast Alu sump
