Popular Post Mark19691 Posted December 7, 2024 Popular Post Posted December 7, 2024 Just recently bought my first Westfield a factory built sport 2000 Duratec, and joined the club. Thanks to Cheshire group for advise. Looking forward to some nicer weather and getting out to a few trackdays and meet ups next year. First item on the list of to does, removable steering wheel. 11 Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 7, 2024 Posted December 7, 2024 Welcome to you and your great car @Mark19691 We'll look forward to seeing you again with your car in the new year! 1 1 Quote
Rob Hunter - Club Secretary Posted December 7, 2024 Posted December 7, 2024 Welcome mate! Looking forward to seeing the car in the flesh! 1 1 Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 7, 2024 Posted December 7, 2024 8 minutes ago, Rob Hunter - Club Secretary said: Welcome mate! Looking forward to seeing the car in the flesh! Never mind trying to nab our Cheshire Members 😉 3 Quote
Dave Eastwood (Gadgetman) Posted December 7, 2024 Posted December 7, 2024 Welcome! Looking forward to seeing the car in person!! 1 1 Quote
Benrobson2999 - Joint Kent AO Posted December 7, 2024 Posted December 7, 2024 Welcome! #teamyellow I have just ordered a go race removable steering wheel boss kit. I will post up a little review when it arrives in the post 6 1 Quote
Naranja_Al Posted December 8, 2024 Posted December 8, 2024 18 minutes ago, Mole said: Welcome..best colour and engine... In your opinion of course. I’m rather fond of Zetec powered orange cars 🤣 2 Quote
RickRack Posted December 8, 2024 Posted December 8, 2024 Hi Mark, welcome to the Westy owners club, car looks great & hope to see it in 2025 events and #teamyellow 🫶🏼👍 1 Quote
Mark19691 Posted December 9, 2024 Author Posted December 9, 2024 With the weather over weekend not had a chance for a run out. However gave me time to check the car over further. Checking fluids discovered the cluch reservoir almost empty, and looks like there has been a leak from the diff at some point(not checked oil level yet), will therefore degrease the underside and check further for leaks. Rear dampers were set 5 clicks from full hard, which explains why rear ride was so harsh during test drive. Front dampers were 15 from full hard. Have reset all to 10 clicks from full soft for road driving. Tyres set at 19psi Everything else seems in reasonable order no play in suspension or steering. Powder coating on chassis all looks good with exception of a small patch on the diagonal down by the brake master. Just need some decent dry weather for a drive out. 1 Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 9, 2024 Posted December 9, 2024 Is it a concentric clutch slave? It's not unknown for them to leak. Not a quick job to check or fix. 1 Quote
Naranja_Al Posted December 9, 2024 Posted December 9, 2024 If it is a CSC maybe you can sneak an endoscope into your Bellhousing to check for a leak? I’ve successfully managed this in the past. Failing this you could fill the reservoir up and pump the pedal and check for leaks at the bottom of the Bellhousing. This would be a leaky CSC or feed / bleed pipe connection. If it is a CSC leak I’m afraid it’s an engine out job to fix. You might be lucky and it maybe a leaking clutch master cylinder. Check for fluid loss around your pedal / master cylinder once topped up with fluid. Re the diff, when I bought my car the breather pipe work was missing and there was signs of some oil loss via the breather. This is a simple check if you have a Sierra diff. The breather is located on the top right of the diff as you look at the diff from behind. I later had my diff re-built be Bara Motorsports as I had some strange clunking noises coming from it. They found a leaking side seal during the rebuild process. So it maybe this too. 1 1 Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 11, 2024 Posted December 11, 2024 @Mark19691 I've split your brake question into a new post in Tech- here- Brake Pedal Feel It's likely to be more noticed and hence better support there. 1 1 Quote
