OB1 Posted April 8, 2004 Posted April 8, 2004 Hi, am I right in thinking that all copper brake lines have Convex ends ?? (I'm looking to replace some flexi hoses and the "bulkhead" fittings at the front - just want to make sure I order the right bits before dismantling… thanks Quote
Nick M Posted April 8, 2004 Posted April 8, 2004 I think it varies to be honest. I seem to recall the connection where where hoses come from the caliperss and mate up to the copper pipe would have a concave flare, i.e. they could accept the pointy end of the flexible hose, but the fittings which went into the T-piece at the front of the engine bay had a convex flare, i.e. they needed to be angled in such a way as to sit in an angled "cup" within the T-piece. I know it's a bit s**t or bust, but the simplest way would be to disconnect the fittings and have a look at what's been done previously. Quote
stu999 Posted April 9, 2004 Posted April 9, 2004 Just to add to Nick's good advice, if you havent got an old pipe to compare, look carefully at the fitting/hole the pipe will be going into. It needs to be the 'opposite' to that. If the fitting has a convex end, the pipe will need a concave end, and visa versa. HTH Stu. Quote
OB1 Posted April 9, 2004 Author Posted April 9, 2004 thanks guys - looks like its best to break the joint to be 100% sure... Quote
S8ight Posted April 9, 2004 Posted April 9, 2004 as a general rule of thumb male fittings have a convex flare and female fittings have a concave flare. Quote
