MBE 967EG inductive crank sensor SW>560
Hi Westfield Team !
I currenlty have this working ECU : MBE 967EG, Serial No: 00033563, Software:967BA560 on a 1.8 Zetec with EFI (and Ignition of course).
I'm looking after a spare ECU, as they are not produced anymore. Just in case my current goes dead.
So apparently after careful check, I would need:
HW 967 EG
SW > 560, this means anything with Software: 967BA560 until 967BA622 or later is ok
AND for inductive (2 pins) crank sensors (apparenty standard set up from ford zetec engines).
Absolutely not "Hall Effect Crank sensor" (3 pins), because the HW within the ECU is different than for inductive crank sensors and won't work at all.
Thank you in advance a big thank to anyone having something in this direction to offer.
