NDS Posted September 5, 2024 Posted September 5, 2024 Radical HAYABUSA Gen 1, 1400cc HIGH COMP SOLD Rebuild by Karl at Extreme engines fitted with new dry sump and pump , Jenvey throttle bodies, carbon air box Radical exhaust system and 7 style big bore system , Spare long shaft starter , Radical clutch slave cylinder set up. Remote electric water pump. Would suit a seven or single seater / Radical Ross Racing Piston Kit 84mm Stage 2 Cylinder Head Race Gas flow plus short bronze guides Cylinder 84mm Re-plate H/duty Valve spring & retainer kit Billet H27 Cams and adjustable sprockets Set H/Duty Cam Cap Bolts Set new connecting rod bolts 1 cam chain 1 Full Set Gaskets, V-Stem Seals, Clips etc. 1 cam Cahin tensioner 16 used Genuine Suzuki Valves exhaust /intake 10 main bearings 8 B/E bearings Set tappet shims Offers over £8K Can arrange delivery. Please PM
