Dusty Posted April 5, 2004 Posted April 5, 2004 Hi all. First post. I'm joining a zetec 2.0 to a T9 and was looking at the flywheel on a Zetec S 1.25. Much smaller than the 2L flywheel. Does anyone know if it will bolt on and work with the 1.8CVH starter? Looked as if it would. Or is it best to stick to the 1.8 flywheel? Dusty Quote
Ray Grilli Posted April 5, 2004 Posted April 5, 2004 Hmm, not sure a 1.25 flywheel will fit a 2.0 Zetec. They're findamentally different engines. If the bolt pattern's the same you might be in luck.... Not sure re starter though. Ray Quote
