Wanted insta 360 camera mount for the roll cage
Hi everyone I'm after a clamp to put on my standard westfield roll cage to mount my insta 360x4 camera or can anyone direct me to wear I can get one from .
Many thanks Andy :white-westy:
Andy, with my X2 I use a Small Rig clamp like this which works well, easy to remove although I also have the quick release clamp from Insta which makes it even easier.
https://amzn.eu/d/1XZsIo8
You can also get tube clamps from someone like DuraTruss which are probably more secure, although you need to replace the bolt with one which fits the Insta. this one fits my roll bar, not sure if yours is the same diameter.
https://www.thomann.co.uk/duratruss_big_jr._clamp_100kg_black.htm
Finally I have also used some like these for other purposes but I’m sure they could be made to work with the Insta… Can’t recall the source for these.
I always use a thin wire tether too, just in case, and have the Small Rig cage for it too as that gives extra mounting points for the tether.
https://amzn.eu/d/bYZb4lM
Hi Stuart
Many thanks for the info I will check it out and sort one
Thanks again mate
Andy:white-westy:
11 hours ago, Big Andy said:
Hi Stuart
Thanks again mate
Andy:white-westy:
I use one of these
https://store.insta360.com/product/x3_utility_frame?c=2114&from=accessory
With a GoPro Roll Cage mount
https://gopro.com/en/gb/shop/mounts-accessories/large-tube-mount/AGTLM-001.html
I’d like to find a mount that would allow me to mount my Insta360 on my roll cage cross member. Currently it is mounted on the top bar in landscape format and it feels a little ‘exposed’.
A tether is recommended too as suggested by @Stuart Davis AO - Devon Cornwall & Somerset
I use this...
Yes, if you combine that with a quad lock mount you can do it at any angle and direction.
The Small Rig clamp kit comes with everything to allow full range of movement, only £19.99 and great build quality 👍
