GarethHD Posted August 11, 2024 Posted August 11, 2024 Pair of Italian Weber 45 DCOE carbs in good original working condition with matched inlet to 1.6XFlow and itg air filter; carbs worked fine 2 years ago when engine last ran; throttle linkage not included; fitted with 32mm chokes, trumpets are 26mm; two inlet to carb studs have seized nuts and one stud is short and not original; but easily replaced; needs Thackeray or rubber cup washers. FREE carb bush set (8 x bushes and 16 cup washers) included. Whole package £750 ONO. Could split carbs, inlet and air filter if necessary. Any questions please message. Many thanks Gareth 1
