SOLD - Westfield SEIW - SBD Vauxhall Redtop 2.0 - 249 BHP
So, after 15 plus years of Westfield ownership, its time to move on and on to a new automotive adventure, not sure what that is yet, but there will be something.
Reason for sale – All to do with me I’m afraid, early this year during the first Hill Climb I only managed 1 of the 2 days at Gurston due to back pain and pains running down my legs ☹.  After seeing a specialist and getting scanned, it turns out I have a Prolapse Disc which is causing my Sciatica down my legs. I am on the mend, but been told to take it easy for a while……….. not good at doing that.
That’s the boring bit out of the way, so here comes the good bit for someone.  Below are the details of my Westfield for sale.
I have had the car for 2 years (wow that’s flown by) in that time I won the Midland Speed Championship Group 2B in 2023.
The car needs for nothing (apart from an MOT, which I’ll get done for the new owner, so will come with 12 months)
This is a Road legal sprint/hill climb car.
Price - £16500
Private Message me if you're interested.
The below is the info from the previous owner who is a friend of mine and said he’s on hand if there are any questions the new owns has (he’s a nice chap)
Westfield SEIW – WSCC Speed Series Championship Winning Car (a few years back now)
1996 kit, registered 01 May 1997
Complete nut and bolt rebuild 2015 – 2017, back to bear chassis re powder coat etc
Folder full of receipts going back to 1996 when car was purchased from Westfield
Engine
All parts sourced from SBD
Vauxhall 2.0 XE
Steel crank and rods
Slipper pistons
SBD big valve head
Jenvey DTH throttle bodies
Deep carbon filter plate to accommodate long trumpets
SBD 4-1 manifold
SBD Carbon 7” silencer (repacked in 2022)
SBD light weight alternator kit (replaced in 2022 and comes with a spare)
Off set starter to accommodate small light weight flywheel
Dry sump
Aluminium deep core radiator
249.3 BHP @ 8,300 rpm
178.8 Trq @ 6,100 rpm
Safe to 9,300 rpm, shift light set at 8,900 rpm
Clutch / Flywheel
5 3/5 inch twin plate clutch
Lightweight flywheel
Hydraulic central release bearing
Gearbox
Quaife 26Z 6 speed close ratio straight cut sequential
2.39
1.691
1.337
1.151
1.000
0.930
Refreshed 2015, 5 events only since
Diff
Sierra 7” Quaif ATB
4.4:1 CWP
Lightened CV joints
Lightened stub axles
Brakes
Front Willwood 4 pot
Vented discs
Mintex M1155
Rear Sierra
Solid discs
Mintex M1155
Floor mounted adjustable pedal box
Suspension / uprights / hubs
AVO rose joint dampers (AVO Refurbished 2022 all 4 due to 1 leaking)
Fully poly bushed
Front ARB
Rear ARB
Front Lightened cast uprights and aluminium hubs
Rear Westfield aluminium uprights
2.4 ratio Quaife quick rack
Chassis
Addition bracing added to:
Engine bay
Front of chassis
Diff cage
Removeable diff cage brace
All panelling in carbon fibre, Sikka Flex bond and rivet
Detachable carbon / aluminium honeycomb composite floor
Full Caged roll cage
All cage mounts welded and sleeved to chassis, not bolted in!
Wheels / Tyres
Compomotive CXR
Black
8” front
9” rear
Avon ZZS tyres with load of life left, new in 2023
Bodywork
Lightweight GRP bodywork
Detachable rear section
Detachable rear wings
Detachable engine bay panels
Aero screen
Full Carbon lightweight Dash
Full Carbon Rear Diffuser
Misc
Carbon flat floor from back of Engine Bay to the back of the car
Bespoke lightweight wiring loom
Detachable steering wheel
Odyseey Extreme Gel Battery (New 2022)
Additional carbon tunnel top if no handbrake used
Weight in road trim 544KG
TRS 5-point harnesses
Stack rev counter / dashboard / sequential shift lights
Additional shift light on top of scuttle
Oil pressure / temp gauge
Water Temp Gauge
Full Video Recording setup with forward and driver cameras, GPS, throttle, brake, gear selected (See the attached video)
Spears at extra cost (so not inc in the price above)
·         Blue wider Rear Arches
·         Indoor car cover
·         Orange standard Rear Arches
·         Full set of Wish Bones (Front and Rear)
·         Set of Split Image Wheels (I think they’re 10” and 8” wide, with another outer to make them 9” and 8” these come with old AVON Slicks)
·         Used Engine – 2.0 its stock apart from ARP rod bolts, SBD cam cover and a QED Shallow Sump with pick up pipe.  Photos on request.
·         PRG TracSporter (GROSS 2,600KG Version) with trailer movers and full LED lights
Engine Video
Dash Video
Video SW footage
Fantastic car, gotta love a well sorted XE 🤩
GLWTS
  • Tom Frankland (T3OMF) changed the title to Westfield SEIW - SBD Vauxhall Redtop 2.0 - 249 BHP
What a machine. All the best Tom, this won’t be for sale long 👍🏻
  • Tom Frankland (T3OMF) changed the title to SOLD - Westfield SEIW - SBD Vauxhall Redtop 2.0 - 249 BHP
Car has been sold and collected.
So next is to go through the loft and sell everything I have Westfield related
You have been warned ;)
  • Sad 1
