Insuranceman Posted July 28, 2024 Posted July 28, 2024 Has anyone got a one piece steering column? The one i’m after is in the engine compartment and was supplied when the kits were supplied with the zetec on itb. I have been in touch with Westfield but they are telling me that they don’t supply them anymore and don’t have any technical drawings to get any made!
Ansoeb Posted July 28, 2024 Posted July 28, 2024 Speak to Andrew at Toybox as they often have parts available
TableLeg Posted July 28, 2024 Posted July 28, 2024 If you get really stuck or depending on the costs you come across for sourcing a one piece column you could always do as I did and buy the parts for making your own column. I purchased the 600mm double spline ended column and had it cut and re-welded (by a professional company). https://www.carbuilder.com/uk/search?q=steering
Insuranceman Posted July 28, 2024 Author Posted July 28, 2024 5 hours ago, Ansoeb said: Speak to Andrew at Toybox as they often have parts available Ok, will give them a call.
Insuranceman Posted July 28, 2024 Author Posted July 28, 2024 1 hour ago, TableLeg said: If you get really stuck or depending on the costs you come across for sourcing a one piece column you could always do as I did and buy the parts for making your own column. I purchased the 600mm double spline ended column and had it cut and re-welded (by a professional company). https://www.carbuilder.com/uk/search?q=steering Looks like i will use this route if no luck with other routes.
Insuranceman Posted July 28, 2024 Author Posted July 28, 2024 47 minutes ago, Rednop1 said: I'm sure I have one If you do what would be the price?
