Fuel Tank for Sei
Hi, has anyone got a fuel tank with fuel injection provision for sale to fit my SEi or one that can be modified?
@John Higgins It’s quite easy just to get the tank modified see this thread on what I did, plus with the pot in the middle it will be better for fuel surge.
I bought the ally, folded it my self and did all the prep work. Then just got my local welder to weld it in. Probably cost less than £50 inc the welding 👍🏼
Hi Matt, thanks for the link, very interesting. I could do something similar except that I would like to install an in-tank pump set up from a Fiesta ST180 or similar. This avoids the need for swirl pot, pre-filter and separate fuel gauge sender unit so ultimately should be lighter. I do have the skills to fabricate a complete tank if necessary but my TIG welding skills are a little rusty! Cheers, John.
@John Higgins Here’s an example of what your looking for it sounds like (page 2)
Hi Matt, Tim Reid's build is very good and sound like the solution I want. There's one thing that I didn't understand and that's the lack of a fuel return pipe. I have AT Power TB's and the fuel rail has in and out. Perhaps someone can clarify things for me.
@John Higgins I run a dead head system, so just one feed line to the fuel rail.
If you look at the first thread in my first reply there is a fuel system diagram, I take it the ford fuel pump will work the same hence one feed coming from the tank to the injectors.
@John Higgins Here’s the specific point about the Fiesta fuel pump it has a self return hence only needing the one fuel line to the throttle bodies.
I just blanked off my fuel line with a screw on cap form Torques.
I run a dead head system fuelling system too, blanking off the fuel rail in the same way as @Matt_S has.
Thanks guys, all very neat and tidy. I'll post some pictures when I've built it all. Cheers, John.
