Do i have to use full bucket seat for hill climb, problem is the width as i'm a little portly, the hip support is to tight with bolsters, perfect fit without.
No need for a ‘proper’ seat even!
you could do a foam insert onto the aluminium panels if needs must, the only thing they might check for seats is the rigidity if it’s a high back or if the back doesn’t look well supported enough at the rear.
As the seat forms an integral part of the safety system with the seat harness you need to make sure that it will support you in the event of a crash. Especially if you hurtle backwards into something.
  • 2 weeks later...
Is a head/helmet rest required by msuk? It’s def a good idea to fit one if not using a high back seat.
