Richard (OldStager) Posted June 8 Share Posted June 8 I am in need of a 40mm long spacer with a 8mm I.D. hole in it, O.D. can be any size within reason say max of 20mm O.D. Can be made from alloy or steel - NOT plastic as it is under compression in use. I am converting a car from a generator to an alternator and need this for the mounting setup, I have nothing suitable. Do you have anything knocking about or are there any machinists in the house?. Thanks. Richard. Link to comment Share on other sites More sharing options...
Ansoeb Posted June 8 Share Posted June 8 I can make what you need, send me a wee drawing of what you want and I will get it done this week. Link to comment Share on other sites More sharing options...
Richard (OldStager) Posted June 8 Author Share Posted June 8 @Ansoeb Hiya, Thank you for offering to make me one, I hope the photo below makes sense ?, with a 8mm hole in the centre going full length. I made up a dummy just to test things, so needs this doing properly one I get the car back on the road. Any questions, just message me back. Thanks again. Richard. 1 Link to comment Share on other sites More sharing options...
Ansoeb Posted June 9 Share Posted June 9 No problem, I will let you know when it’s ready to post, then you can give me the address etc. 2 Link to comment Share on other sites More sharing options...
