Rogers79 Posted May 31 Share Posted May 31 Due to other opportunities up for sale is my Westfield Megablade. It is fully road legal ex ToyBox car currently set up for sprints and hillclimbs. Very quick car which was 2nd overall at Watergate bay, Shelley Walsh 32s, Luton Park 56s on 1b tyres. Spec below, any queries please let me know. Westfield Megablade Q398 VBD Registered April 2009, 2650 miles. Major overhaul 2018. Engine 2018 Honda CBR1000RR Honda WSBK endurance engine. Rebuilt 2019, spec sheet available. Installed 2023 and set up by Daytuner 185bhp. Less than 50 miles since rebuild. AB performance air box AB performance exhaust system including balanced manifold Water delete kit Garagisti dry sump kit with SBD dry sump tank. Oil cooler Deep core radiator Davis craig water pump Suter slipper clutch Nova close ratio gearbox Track electronics bespoke engine wiring loom Opened Honda ECU (flashed) Quickshifter flat shift Power commander 5 Healtech gear indicator Differential Sierra 7” 3.3 CWP LSD – Refurbished by Bara May 2024 Starter motor reverse gearbox Brakes AP racing master cylinder – New May 2024 Hi Spec front calipers – Hawk DTC30 pads new May 2024 Sierra rear calipers Suspension Protech double adjustable fully rose jointed Siltech extra wide front wishbones fully rose jointed Siltech front anti roll bar Siltech lightweight front uprights and hubs 2.4 quick rack Westfield rear alloy uprights Geometry set up and corner weighted by Ian Dayson Chassis / body Orange – V8 bonnet, FW rear with detachable rear wings Carbon CSR style front wings Carbon rear diffuser Carbon transmission tunnel Carbon rear bulkhead Carbon aeroscreen Westfield full FIA cage Not fitted but available front bulkhead carbon panels. Compomotive CXR 13” gold wheels Tillet B5 carbon drivers seat TRS 6 point FIA harness – New 2024 Tillet bambino kart seat Westfield 4 point harness Carbon effect dash Complete Stack professional gauges, oil temp, oil pressure, water temperature, 14k tachometer with tell tale Detachable steering wheel Soft bits split tonneau £13950 1 Link to comment Share on other sites More sharing options...
Rednop1 Posted May 31 Share Posted May 31 Porn !! Link to comment Share on other sites More sharing options...
Kingster Posted May 31 Share Posted May 31 43 minutes ago, Rogers79 said: set up by Daytuner 185bhp Damian usually quotes wheel bhp - if that’s the case this car will be rapid! 😍 1 Link to comment Share on other sites More sharing options...
