The time has come to part with my Mega S2000 and let somebody else have some fun!
Owned this vehicle since 2017 but a hectic life means it has spent the last 20 Months parked up in my garage. Well known vehicle amongst the WSSC peak district area members.
Vehicle Spec
Engine
Honda F20C
The Engine was fully stripped and rebuilt to the following Specification with all brand New parts.
  • Oversized Carrillo High compression forged race Pistons 87.5 (compression ratio now 12:5/1)
  • Block was bored from RFB to steel liners to take oversized race pistons.
  • 16 x New Supertec race valves.
  • Crank, checked for journal sizes, polished and balanced.
  • Rods crack tested and balanced.
  • Cylinder head was fitted with 16 new race bronze guides.
  • Skim to clean, 3 angle valve seats cut and pressure tested.
  • New Genuine Honda timing chains.
  • ARP Head stud kit fitted.
  • Multi-layer steel head gasket.
  • ACL Competition race bearings for mains and Big ends.
  • Stock Honda throttle body.
  • K&N High flow Air filter.
  • Mocal Oil catch can
  • Remote Oil pressure sender.
  • Oil Temp sender
  • Baffled Sump
  • Carbon Exhaust
  • De-Cat pipe (Standard CAT as spare for MOT)
  • Odessey PC680 battery (New in 2023)
  • OMEX 610 ECU (Unlocked) and can be tweaked via MAP4000 on your own PC if you have the knowledge.
  • Produces 276 bhp & 178 ft lb torque.
All Engine work was carried out by AP Racing Engines Ltd @ approx. 2500 miles on the odo. The engine was run in and dyno tuned on AP Racing engines Ltd Premises.
Drivetrain
  • Honda S2000 Gearbox.
  • Lightweight billet steel flywheel
  • Stage 2 paddle clutch.
  • 7” 3.62 ratio Quaife ATB LSD
Braking & Suspension
  • Protech adjustable Shocks.
  • Westfield Wide Track Front end.
  • Westfield Big Brake Upgrade.
  • “Playskool” Front & Rear ARB’s (Soft)
  • All suspension components polybushed.
  • Aluminium Uprights
  • Hi-Spec Calipers Front & Rear with Ferodo DS2500 pads.
  • 15” Team Dynamic 1.2 in Gloss Black with Toyo R1R Tyres (Almost New)
  • Spare set of 13” Team Dynamic 1.2 in Gloss Black with Toyo R888’s (Low tread, used on track days)
  • Full suspension & geometry setup at Playskool motorsport after polybush install
Exterior
  • Real Carbon front cycle wings (Carbon NV)
  • LED headlamps (New in 2023)
  • Full roll cage by Caged.
  • Heated windscreen
  • Carbon effect rear stone protectors.
  • FW bodywork with V8 Bonnet in two tone Blue/Black.
  • F1 Spa style wingmirrors.
Interior
  • Westfield Sport Turbo seats with blue trim.
  • Race Technology Dash2 Pro.
  • Longacre wide view mirror.
  • Carbon effect dash
  • Momo quick release steering wheel.
  • Westfield lowered floor pans.
General Info
Fresh MOT until May 2025. Car is in excellent overall condition & ready to drive away. This car is a real head turner.
All fluids (Engine, Braking, Coolant, Gearbox, diff) replaced approx. 300 miles ago and has only ever been filled with Fuchs Titan Race oil. RPM is set at a conservative 8500rpm but engine is capable of 9500rpm
Gearbox is excellent but one of the gearlever springs needs putting back on as the lever does not return to centre on one side and I dont have time to repair it myself.
No tyre kickers please, genuine buyers only.
Im sure there are things ive missed so please ask if you have any questions.
Car is Located in Nottingham.
£20,000
  • Like 4
I'm sorry to see this great car go @Scotty72 That's a great offer you've put together and I don't expect it to hang around for long.
Thanks Ian 👍
Oh no, didn't expect this @Scotty72! Stunning car though mate, someone will be getting an awesome motor 👌
  • Scotty72 changed the title to Westfield Mega S2000 for sale **Reduced Price** £23,500
Price reduced to £23,500
  • Scotty72 changed the title to Westfield Mega S2000 **Price Reduced**
Now being advertised elsewhere...
  • Scotty72 changed the title to (SOLD) Westfield Mega S2000
