NickT Posted May 1, 2024 Posted May 1, 2024 (edited) Factory-built wide body Westfield SEiW. 1.8L Zetec engine with 2.0L cams giving 149bhp. Ex ToyBox car so has the ToyBox headlights and the carbon-effect body stripe. 14800 miles from new. ULEZ compliant. In 2018 Northampton Motorsport fitted Zetec 2L cams and replaced the timing belt, water-pump and thermostat. The MBE 967 ECU was set up on their rolling road to produce 149bhp @6900rpm with a nice flat torque profile. See photo copy of the dyno printout. Note the engine has the Westfield intake plenum and sports cat exhaust with heat-shield. The car is very driveable and pulls strongly and smoothly even at full throttle from low revs. The car has un-marked Team Dynamics Pro Race 1.2 wheels with Toyo Proxes. There is also a matching spare for fitting on the back. The suspension is adjustable for ride-height and damping and has an adjustable front anti-roll bar. The underneath of the car is very clean and rust-free. The bodywork is in good condition and has the quick-release nose-cone. The car has Westfield seats and harnesses and is carpeted throughout. The steering wheel is quick-release with a Westfield boss. There is full weather gear (side windows, hood and frame) which can fold down into the rear lockable boot-box. In addition there are a pair of Perspex wind-deflectors which can be used as an alternative to the side windows. There are two keys and the car has a key-operated (hidden) electrical cut-out for security. There is a fused USB power supply under the dash. The only minor fault is that the plastic screen bow which is bonded to the hood and sits on top of the screen is broken in the middle where the notch is. This is apparently a common problem because of the design. The hood still fits OK but I suspect at speed it would lift in the middle (I’ve never driven it with the hood on so I don’t know). Replacement trims are available for £49.99 from Westfield-Sportscars P/N 5559001 should you see the need! https://westfield-sportscars.co.uk/shop/5559001-hood-trim-extrusion-to-suit-standard-wide-body-windscreens-9293?page=2&category=135#attr= The car comes with a water-proof, breathable cover. I have owned the car since September 2023 when I bought it “on a high” after having successful surgery. Unfortunately the high has not lasted and I realise that I’m too old and decrepit to use it as planned – hence it is up for sale. Hey ho! I can be contacted on gd427car@gmail.com Edited May 3, 2024 by NickT Car is sold
