Siltech - Wilwood Brakes
Siltech supplied Wilwood front calipers 120-8726 fitted with Hawk DTC30 race pads
Wilwood rear calipers 450-8725 fitted with Hawk DTC30 race pads
Wilwood master cylinders 0.625 & 0.75
Hel stainless hoses
Siltech supplied lightened rear disc, showing signs of stress cracks
Standard rear discs
Siltech supplied front caliper brackets
Custom front & rear caliper brackets machined from billet and hard anodized
The new boxed Hawk pads in the photo are not included, they are for sale separately
£700
I suppose the rear calipers do not have handbrake, is that right?
Correct, this setup is from my track car.
  • 2 weeks later...
May split depending on what you want
What uprights are fronts for? Will they fit Cortina Mk3/M16
Hi , see you have 6 mounting brackets , would be interested in a pair for front caliper mounts
They are for the later uprights, were fitted to a 2018 car
The WF alloy uprights are all based on cortina upright geometry and fittings though and to my knowledge that never changed.
What do we need to measure to be sure?
Would the calipers still fit even if I had to buy new brackets from Rally Design/Siltech?
Have no problem doing this piecemeal if its cheaper than buying it all new..... (tight git, I know....)
Second what @Kingster said, all Westfield front uprights are based on the Cortina geometry, so they all share the same caliper mount points.
In which case @Smudge62 can I have a price for:
Front calipers
Brackets (posh ones preferred)
Front hoses
Postage, unless you're anywhere near East Hampshire...
Can you also confirm which diameter discs I'll need?
Because the uprights are axial fitment and the calipers are radial, you may find that one or more if those mounting brackets will suit different disc diameters by spacing out the caliper.
Still for sale
  • 3 weeks later...
Both sets of calipers sold
One set of hoses sold
Both master cylinders sold
