TANGO6 Posted March 9, 2024 Posted March 9, 2024 Westfield Megabusa 1298cc 2001 factory built car Y registration 6001 miles Immaculate condition for age Standard spec Engine/chassis: 1300cc standard Suzuki Hayabusa Westfield dry sump system Westfield reverse gearbox Freelander 1 rear diff fitted with Quaife ATB Westfield non cat silencer Nitron height/damping adj suspension Westfield Front and rear Anti-roll bars Westfield HS Alloy 4 pot front calipers Westfield aluminium front/rear uprights Braided brake hoses Image split rim 7 x 13 wheels Avon zzr 185/55/13 83w tyres Trickle battery charger fitted Bodywork/Interior: Orange gel coat factory Carbon arch protectors Carbon fairing for clear aero screen Carbon effect rear light housings Carbon effect rear top cover Fia cut out switch Half cage MSUK approved Carbon dash Momo gear knob Alpha leather detachable steering wheel SPA tacho/rev counter with shift lights SPA water/oil temperature gauge SPA rear view mirror Racetech oil pressure gauge Geartronics gear indicator Willans 5 point harness's Westfield padded race seats fixed subframes Floor mounted pedal box Westfield tonneau cover Westfield half doors Extra parts included: New bonnet New headlamp New gear change rod New oil filter New Castrol racing oil Used Westfield cat silencer Used Image alloy wheel 7x13 Used front Nitron shock absorbers Used Smoked aero screen I have owned this Megabusa since 2006 Maintained to the highest standard regardless of cost Oil and filter replaced every 100 miles Checked over after every outing and detailed Mostly used for Hillclimb's and road use Mot till 28.9.2024 V5 Also MUK logbook Original order form/invoice for car and other various paperwork/invoices The car is as it left the factory apart from a Flat shifter system for up and down clutch less gearshifts More info/images available Car is based in West Lothian Scotland £14750 4
