Will I have to fit  an Isolator key to my ignition system on my  Seight  for class B road going hair dressers section
I read in the the blue book
" An external circuit breaker to Q8 is mandatory for all cars except open cars of periods A-E section P and cars listed for road use (when it is recommended)"
It's the 'When its recommended' bit that's a bit vague.
I was thinking of marking up with a sticker the direction of off/on indicator relating to the ignition  .
I really don't want to be a putting a dead mans key on my car as its an ugly mother.Plus primarily I want to keep the car as road standard as poss plus I will be doing six  rounds max this year
Any help/advice
Buzz :cool:
Dont you have an ignition key then?   :D
If so, take it as NO. Just mark the off position somehow.
John
Means you don't have to do it, it's just that it is 'better' to do whatever is recommended IMO.  Like you and many others, I just run with a sticker indicating what to do to turn to off the ignition / engine.
Me too. No kill switch on my car.........
ONLY a kill switch on my car  :D
Cheers guys at least I don't have to nick it of my red westfield now.Sticker it is then
Buzz:cool:
If your car is already an ugly mother, what difference will adding a kill switch make?? ???:D:p
ooops I meant my sister or was it my mother.....F**ker?
Cut-off switches are not mandatory for any road-going cars in sprints and hillclimbs  ;)  ;)  :D
What is mandatory is as noted a sticker on ignition indicationg "Off" direction  ;)  :D
If you do fit a cut-off switch it must turn everything off engine, fuel pump the lot  ;)  :D Total shutdown, battery and everyfink  :D  ;)
Hey Buzz, when you're sat in the car, I don't think you need worry bout the prettiness of yer switch  :arse:
Cha'heeky kin' bar steward  ;)  :D
Buzz :cool:
