Hayabusa engine cradle/frame and exhaust manifold
I'm looking for an Engine cradle for a Busa engine, to original Bike engined chassis.
Also Busa engine manifold.
Let me know if you have anything sitting around, like we all do ;)
Can you not get one of the lads to help fabricate one?
Nick there was somebody on Facebook advertising a cradle some time back and the same with the manifold maybe put a wanted listing on there?
I have a couple of options. please PM for details :
  1. Gen 1 Hyabussa , bike compete 42K miles with full service history including intermediate oil changes.
  2. Ex Radical SR3 race engine unrun built by Karl at Extreme Engine., Jenvey throttle bodies ,
    1. SUZUKI HAYABUSA Gen 1 1400cc  HIGH COMP Drysump , Drysump Tank, Radical clutch activator system, Electric water pump
      Stage II Cylinder Head Race Gasflow plus short bronze guides
      H/duty Valve spring & retainer kit
    2. Billet H27  Cams, & Adjustable  sprockets
      Set H/Duty Cam Cap Bolts
      Set new connecting rod bolts
      1 cam chain
      1 Full Set Gaskets, V-Stem Seals,Clips etc.
      Cylinder 84mm Re-plate
      Ross Racing Piston Kit 84mm
      1 cam cahin tensioner
      16 used Genuine Vaves exh /intake
      10 main bearings
      8 B/E bearings
      set tappet shims
  3.  Keihin 40mm  Carbs Ex radical
  4. ECU and engine harness -  carb engine
  5. ECU and engine harness carb engine (condition unknown)
  6. Exhaust manifold - big bore
  7. Spare long shaft starters
That's plan B ;)  I've got a GSXR Cradle so can use to copy basics if needed.
      1 cam chain
      10 main bearings
      8 B/E bearings
      set tappet shims
Thanks for your list, I've got most of those kind of things myself. But will PM about Exhaust Manifold.
Engine Cradle now sourced. Thanks
Busa Manifold still wanted.
