SootySport Posted January 12, 2024 Posted January 12, 2024 43 minutes ago, Kingster said: I tried GoreTex as well as some of my expensive mountain biking eVent gear over the years. But when it came to serious rain over an extended drive the breathable materials eventually let water in as you sit in the literal “bucket” seat because they are simply not designed for immersion. Either that or it gets in the seam that is always in the middle of the jacket and creased around your crotch area. A bike one-piece with a diagonal zip arrangement is significantly better. But you will sweat and thus still get wet. The reality is that if you run an aeroscreen, you just have to take it on the chin (or turn into an old wuss and get a car with a proper roof ) Yes, nothing prevents leaking when immersed in water but I found Gortex is as good as you get, short of a fully waterproof one piece suit and then yes get condensation. Rather go for slight leakage myself. Quote
Andrzej Posted January 13, 2024 Posted January 13, 2024 Some time ago I bought such one piece police suit (British BTW ) cheap here in Poland : https://armyworld.pl/product-pol-14089-Kombinezon-Wodoodporny-Ochronny-Policyjny-Brytyjski-Remploy-Granatowy-Oryginal-Nowy.html Intended to use on wet trackdays in Westfield, but such never happened so far. I use it for long walks with dog in rain, snow etc. Few years so far. Must say I always stay dry inside, it breathes very well , no sweat inside, best to wear one of those thermal clothing under, layers depend on temperature. In UK those should be easily accesible Here it was approx 40GBP (New , never used) . Quote
SXRORY Posted January 14, 2024 Posted January 14, 2024 On 11/01/2024 at 11:56, Kingster said: Yeah - one piece can keep you dry but you sweat on the inside and then… get wet here’s how I solved the problem Have you done a post about the lotus? Thoughts and was the change everything you hoped. I'd read it anyways looks bang on Quote
Kingster Posted January 14, 2024 Posted January 14, 2024 8 hours ago, SXRORY said: Have you done a post about the lotus? Thoughts and was the change everything you hoped. I'd read it anyways looks bang on Not yet but will do 1 Quote
