Any clues as to the thread size on the zetec block for fitting an oil pressure sender? I'm assuming the normal place to fit the sender is onto one of the two tapped holes on the oil filter side of the block?  My greengauges sender is a smaller diameter fitting (I think 1/8 27 NPT), so I need to get hold of a suitable adapter...
Cheers,
Neil
Neil,
I had to get an adaptor for my 1800 Zetec to fit a VDO pressure sender. I got one from Burton Power, part no LMA006 which is described as 'adaptor 1/4npt(m) - 1/8npt (f)'
It does the job & cost £3 + vat.
Simon
