5 3/4 led headlights
6 hours ago, CosKev said:
Not a fan of the LED ones like above with the smaller round lenses inside myself,just look too modern/put of place on a seven imo😏
These work well,but don't have a side light.
DRL could do with a bit bigger, but think they suit a seven type car much better 👍
I have these but for ease I wired the DRL as a sidelight.
No issues with MOTs and they are surprisingly effective as headlights.
Can't remember how much they cost,  but they were cheap and cheerful from AliExpress.
5 hours ago, RickRack said:
How do you get thru MOT?
Taken from the MOT testers manual;
"Vehicles do not need to be fitted with position lamps, or may have such lamps permanently disconnected, painted over or masked if they are:
only used during daylight hours, and
not used at times of seriously reduced visibility
In this situation, you should issue an advisory."
14 hours ago, RickRack said:
Do you have side lights?
Sidelight is between the two lower lenses.
