FS: Matched set of 4 peco injectors - Siemens Deka 630cc EV1 multihole - price reduced
Posted (edited)
Flowmatched set of 4 Siemens Deka 60LB 630cc Compact (Peco) Fuel Injectors FI114962
4 hole 30 degree spray pattern - as recommended/sold by SBD and others for up to 450bhp in batch injection, retail at £85ea.
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
Gain: 0.11ms/mg, Offset: 0.055ms, Turn on time @ 14VDC: 1.14ms, Turn off time: 0.85ms @ 600KPa
Connector: Bosch EV1 with factory fitted with Viton upper and lower o-rings
Set of 4 used for <1000 miles on a high spec Duratec.
£100 collected from Coventry/by arrangement or £105 couriered.
Edited by sideways_stu
reduced price
  • sideways_stu changed the title to FS: Matched set of 4 peco injectors - Siemens Deka 630cc EV1 multihole - price reduced
