David Francken Posted September 23, 2023 Posted September 23, 2023 (edited) Hello there, I’m from Belgium and I’m searching a nose cone for my westfield. It is westfield Se 2-axle-rigid body. My nose is broken. Has anyone such part at home? Post me likely… greetings David Francken. Edited September 23, 2023 by David Francken Quote
Mark (smokey mow) Posted September 24, 2023 Posted September 24, 2023 Hi David, there were two types of nose used on the SE which are referred to as hi-line and low-line, the are not interchangeable so you would need to check which you have. the lowline has been discontinued for many years but the hi-line can still be bought new from Westfield https://westfield-sportscars.co.uk/shop/1131302-std-narrow-body-nose-cone-7492#attr= Quote
David Francken Posted September 24, 2023 Author Posted September 24, 2023 Ok thank you very much Mark! How do I know which one I have? My chassisnumber is 91WSE2381. I think I have a small one…so I guess low line…my front grill is much less wide in height, small grill... Quote
Dave Eastwood (Gadgetman) Posted September 24, 2023 Posted September 24, 2023 There's a guide on the forum, measuring what you have, to compare is the only safe way. - Don't forget, the older a car gets, the less you can assume - there's not necessarily a guarantee bodywork is original. How to tell low line from the later standard bodywork. Quote
