  • Westfield SEIW Chassis with unrecorded V5 (Q plate) – Damaged Needs front end repair
  • Genuine Front Aluminium Uprights, Alloy hubs, Discs and alloy 4 pot calipers
  • Front Wide Track Wishbones and Rear Wishbones with bolts (brand new)
  • Steering Column – Full column, ignition barrel(with 2 keys), steering Rack + extensions + steering wheel
  • Wiring loom - mint
  • FW Fuel Tank
  • FW side panels (need a little work)
  • FW rear end (new)
  • Carbon fibre v8 bonnet (previously repaired. I have the cutout for air filter to make good the opening)
  • Radiator Bracket
  • Duratec engine bracket (RHS only)
  • Cut down windscreen uprights and polycarbonate screen (similar to mofast)
  • Headlight brackets
I believe there is around £4500 of parts here at used prices so looking for someone to take the lot for £3200
Photos to follow tomorrow.
  • Aeruttle changed the title to Sold - Unfinished project
