175 Bhp Pinto
I've done a search on previous posts and I think I have the answer but Iwant to double check that I have it right before I spend some cash. :angry:
A bit more info just before someone asks....
The car will be used mainly on the road with the odd track day. I have silver top fuel pump.
My point is that I belive I need to put a swirl pot in place am I right ?  :oops:
If it's on carbs, and I'm assuming it is, then no.
Pressure regulator, yes, swirl pot, no.
Thanks Blatman, any recommendations just had a quick look on the interweb and there are two types one with a filter one with out ?
I was think about the filter king one ?
Ig I got one of these wheres best to put (no rude answers please). :suspect:
Hi Black Shadow
you need to put it between the pump and the carbs - normal position is on the scuttle panel.
Ally bowl filter king is what I use. Mine is on the scuttle....
