DMc Posted June 8, 2023 Share Posted June 8, 2023 ATL resistance fuel sender. These are super accurate top quality senders. can be cut and calibrated to any length, currently at 295mm to be used with programmable gauges/dash. Supplied with instructions. £100 plus post Link to comment Share on other sites More sharing options...
tr1stan Posted June 8, 2023 Share Posted June 8, 2023 Do you happen to know if this will work with a Stack Dash 8130, I'm guessing you used this with your stand alone stack dash fuel gauge? If so I'll take it please. Tristan Link to comment Share on other sites More sharing options...
DMc Posted June 8, 2023 Author Share Posted June 8, 2023 Yes I used it with the Stack gauge and my AIM dash I can’t confirm wether it will work with your dash but provided the dash fuel gauge can be programmed/calibrated then it will work Link to comment Share on other sites More sharing options...
evosteve Posted June 8, 2023 Share Posted June 8, 2023 Should work with a Stack 8130 as you calibrate the sender using the dash menu. 1 Link to comment Share on other sites More sharing options...
