Pair of Sabelt harnesses
With fitting kit
£250 plus post.
The Sabelt Steel Caterham / Kit Car is a Lightweight 4 point harness with shorter straps and bolt in end fittings specific to Caterham 7 cars and other similar kit cars.
FIA 8854/98 approved for Motorsport use
Bolt in fittings for direct fit to Caterham 7 cars
Lap adjusters located close to buckle for better access and easier adjustment
The Sabelt Steel Caterham / kit car 4 point harness utilises 3" wide webbing on all the straps which helps spread the load and make them more comfortable to wear. FIA approval makes the harness ideal for Motorsport use or for the serious track day enthusiast. Lightweight steel adjusters allow for easy strap length adjustment.
  • DMc changed the title to Sabelt harnesses pair
  • 2 months later...
Bump
  • 3 months later...
Open to offers on these 👍
