spm Posted March 24, 2023 Posted March 24, 2023 Hi, I am trying to fit a Go-Race QR column to my early SEW chassis with the bolt in Allegro outer column, however it has a 1mm narrower pinch point at the lower end stopping the new column from dropping through. Almost like a thin waist band (see pic). Before I look at modifying the new column, would anyone have a later column outer which I assume must be a uniform diameter all the way through, as I have seen plenty fit these Go-Race columns. Thanks Simon
Pco Posted March 25, 2023 Posted March 25, 2023 Would it be easier to just get someone to weld on the end piece then rather than replace the column? I did that and it only cost a tenner from a welder to do. 1
spm Posted March 26, 2023 Author Posted March 26, 2023 Of course that is an option but I have bought the column now, so looking to see if anyone has an outer tube "under their bench" before I consider alternatives. Thanks Simon 1
Pco Posted March 27, 2023 Posted March 27, 2023 22 hours ago, spm said: Of course that is an option but I have bought the column now, so looking to see if anyone has an outer tube "under their bench" before I consider alternatives. Thanks Simon Of course it is. Didn't mean to tell you to stuck eggs. I'd want it to fit too but the go race adapter is only£40 odd quid if I remember correctly. You could end up paying someone that much or more to machine your current housing. Some times is better to cut your losses than bodge something that won't fit.. hard lesson I've learnt for my stubborness
spm Posted March 28, 2023 Author Posted March 28, 2023 On 25/03/2023 at 17:14, Pco said: Would it be easier to just get someone to weld on the end piece then rather than replace the column? I did that and it only cost a tenner from a welder to do. 22 hours ago, Pco said: Of course it is. Didn't mean to tell you to stuck eggs. I'd want it to fit too but the go race adapter is only£40 odd quid if I remember correctly. You could end up paying someone that much or more to machine your current housing. Some times is better to cut your losses than bodge something that won't fit.. hard lesson I've learnt for my stubborness
spm Posted April 18, 2023 Author Posted April 18, 2023 Just a bump for this, incase anyone has one (column upper tube) under the bench, before I take more drastic (and probabaly expensive) action
spm Posted April 19, 2023 Author Posted April 19, 2023 Thats the one. I'll PM you. On 18/04/2023 at 14:49, Crash test dummy said: I think that I've got one. Is this it?
