Near side steering arm for a megabusa
Which way does your steering arm connect? Does the ball joint sit on top or below the arm?
Only S2000 and Sport 250’s use the later chassis with the rack mounted higher. I’d expect his to be lower down and hence the bell joint will enter from beneath.
