SUZUKI HAYABUSA Gen 1 1400cc  HIGH COMP Rebuilt by Karl at Extreme engines in June 2022 .  Still on the delivery pallet. £8500
Jenvey throttle bodies. Extreme engines dry sump system.
Stage 11 Cylinder Head Race Gasflow plus short bronze guides
H/duty Valve spring & retainer kit
Billet H27  Cams, & Adjustable  sprockets
Set H/Duty Cam Cap Bolts
Set new connecting rod bolts
1 cam chain
1 Full Set Gaskets, V-Stem Seals,Clips etc.
Cylinder 84mm Re-plate
Ross Racing Piston Kit 84mm
1 cam cahin tensioner
16 used Genuine Vaves exh /intake
10 main bearings
8 B/E bearings
set tappet shims £8300
Hayabusa Gen 1 engine removed from bike with 40K miles full service history including intermediary oil changes.  , compete with standard throttle bodies, fuel rail etc.
Purchased as a spare engine  £3200
