* SOLD * : ROLL BAR MOUNTED LUGGAGE RACK
In good condition and is secured on the roll bar.
Really cool if you want some extra luggage space on those longer trips like Silverstone Classic or Europe.
£50 including postage
Hi will this fit an Rac bar 🤔
Thanks William
Thanks William
I can't say for sure as I've only used it on the standard bars however my gut says it won't.
Thanks think your shower cap won't fit an Rac roll bar either i don't suppose 👍
Again I'm not sure ... although with this you might be able to modify to fit.
@Rob Waldron is after a luggage rack 👍
£75 including postage
Hi is the rack still available. If so could you please I’ve me the dimensions across the top claps centre to centre and again the lower ones. Are the lower brackets adjustable to give different widths thanks.
@Rob Waldron Yes the luggage rack is still available ...
Top fixings are 90cm (centre to centre)
These are non adjustable but you could fabricate something to make this different if required.
Bottom fixings are 80cm (centre to centre)
These are currently not adjustable for width but it would be difficult to fabricate some brackets, fixings, etc.,
They are adjustable for height and again you could play around with fabricating if you need more.
Total width of rack is 99cm at it's widest (where it would be closest to the driver) and 92cm at it's least widest (back of vehicle)
Total depth is 25cm
Hope that helps?
Total depth is 25cm
Hope that helps?
Thanks Andy I will have a measure up in the morning.
Hi Andy I did some measurements. Sadly I think your rack would require to much fabrication to make it fit. Front to back space roughly 35cm  between the tubes where it would have to sit 85cm and the distance between the front and back tube is 16 cm at the base
thanks for the opportunity though it’s a pity.
@Rob Waldron
No problem at all and thanks for letting me know ... it's a pity the rack wouldn't fit that kind of roll bar set up.
  • 2 weeks later...
* Bump *
Still for sale and price reduced.
Hi Andy, was this fitted to a narrow or widebody? I have a narrow body, but it's not here to measure up as it's having some work done.
I used it on a Widebody but I'm not sure if it will fit a Narrow ... if the roll bar is the same width then it shouldn't have a problem but I don't know if that's the case.
@Dave Eastwood (Gadgetman) - Club Chairman ... do you know if this would fit a narrow?
