Project ; Westfield SE live axle 1989
Westfield SE Live axle Q720 RNH on Sorn First registered 1989
Photos
  • New panels and floor
  • Steering rack diagonal
  • Pre - strip down condition
The chassis had two frost damaged tubes. These have been cut out and replace (On jig)
Chassis jigged and new alloy panels (Martin Batho) manufactured with HD 16swg floor, bulkhead with bias bar inspection panel ,
Floor mounted bias  pedal box with remote M/C
Roll loop with harness bars and welded down links
Bodywork : Tub, Scuttle , nose cone and boot box , ( no bonnet) Westfield1.thumb.jpg.22b1984b5645026c241175537c22578a.jpg
Carbon aero screen - low blade type
Alloy Fuel Tank - carb - single push on outlet
Fuel Pump
Windscreen and uprights
Front suspension with Cortina uprights , M16 caipiers and solid discs, Steering rack and down link
Gaz alloy coil overs single adjustable.
English axle, drum brakes with link bars and Panhard rod
Box of the usual detritus from an abandoned project :  wiring harness,  old school dash board , radiator with fan, seats , four point harnesses,  seats hood,  wheels and tyres.
£4600.00
Engine gearbox package(s)
1600cc Sigma Engine with Puma inlet and throttle body, Newman phase II cams -  £300
Sigma Lightweight flywheel, Helix clutch pack and ARP bolts – NEW  £1000 One of the best upgrades
Sigma DCOE inlet manifold – New £150
Sigma to type 9 bellhousing  - New – £150
Ford type 9 ( with gear stick extension ) - £300
Elite Sequential gearbox, Sigma  bellhousing , concentric release bearing , Gear positioning indicator. £3800
Sigma DCOE inlet manifold with 30mm Jenvey throttle bodies, injector rail – 6 fittings  , carbon filter housing , selection of DCOE spaces  and short trumpets –  POA
Hayabusa engine 42K removed from bike with full-service history harness, keys and fuel pump available.
Hayabusa – Carburettor setup ex - Radical SR3 compete with harness and MDE ECU  - Free with the above engine
  • 3 weeks later...
pm
  • 2 weeks later...
Hi I'm intrested in the chassis.  Would u be willing to just sell that please.
Sorry no it go's complete. ( or I need to rebuild it )
Thanks for the interest
Just to clarify the damage done to the tubes was water/frost.
