Rednop1 Posted December 8, 2022 Posted December 8, 2022 All brand new Standard track and standard widetrack top ball joints 3x £10 each plus postage 2x pending Standard widebone lower maxi ball joints 2x £20 plus postage Sold pending Zetec type 9 clutch cable 1× £25 plus postage 1 pair of black wipe blades £25 plus postage Side screen hinges kits £25 each plus postage Hydraulic clutch master cylinder £25 plus poatage Sold pending Exhaust square mounting rubbers £5 plus postage Fuse box covers 3x pairs £9 per pair plus postage 1 set sold pending Hood header rail £30 plus postage Nose bonnet grommets £5 per pair Plus pat 9x pairs available 1
David Powers Posted December 8, 2022 Posted December 8, 2022 Put me down for 3rd gen ball joints, 2 upper & 2 lower, plus 2 off Track Rod ends, PM inbound Thanks Dave 1
hammie Posted December 11, 2022 Posted December 11, 2022 Ash Can I get a set of nose bonnet grommets please. Jon
TM54 Posted December 11, 2022 Posted December 11, 2022 hi Ashley, i'm after upper balljoints for wide track suspension and steering rack extensions if you have any left? thanks tony
Rednop1 Posted December 12, 2022 Author Posted December 12, 2022 Full suspension bolt sets 2x £30 per set Plus postage 1x set sold 1x pending 1
David Powers Posted December 12, 2022 Posted December 12, 2022 7 hours ago, Rednop1 said: Full suspension bolt sets 2x £30 per set Plus postage Hi Ash, I will have a set of suspension bolts, if they are still available, PM you in the morning Thanks Dave 1
tr1stan Posted December 13, 2022 Posted December 13, 2022 On 08/12/2022 at 11:30, Rednop1 said: Nose bonnet grommets £5 per pair Plus pat 9x pairs available Hey Ash, don't suppose you've got a pair of pins that go with these grommet too?
SouthhamsChris Posted December 14, 2022 Posted December 14, 2022 On 13/12/2022 at 12:33, tr1stan said: Hey Ash, don't suppose you've got a pair of pins that go with these grommet too? Might be worth checking these out and see if they are the same. 1
Rednop1 Posted December 14, 2022 Author Posted December 14, 2022 They are slighty smaller i have a pair in my garage
Wills 57 Posted December 16, 2022 Posted December 16, 2022 On 12/12/2022 at 16:21, Rednop1 said: Full suspension bolt sets 2x £30 per set Plus postage 1x set sold 1x pending Hi Ash are the bolts Stainless Thanks William
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 16, 2022 Posted December 16, 2022 22 minutes ago, Wills 57 said: Hi Ash are the bolts Stainless Thanks William They will be plated steel. You don't want stainless bolts in such an application! 1
Wills 57 Posted December 16, 2022 Posted December 16, 2022 31 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: They will be plated steel. You don't want stainless bolts in such an application! Yes I have heard that before just trying to replace the rusty ones to nice shiny ones.. 1
