Cobra 427 Build
16 minutes ago, BugMan said:
Have to ask how the hell did you break the vice?
I dont think it liked the impact gun on the hub puller when it was clamping the half shaft :rolleyes:
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
12 minutes ago, bollockybill said:
Gary,
I have a rear entry plenum if that’s any use to you.
John.
Hi John,
Thanks but not needed.
I will be fitting a totally different fuel injection system which does not use any Rover parts
A quick tidy up is all I had time for today.
Got a nice box full of shiny painted parts ready to fit to the chassis soon
Why cant all front hubs have a grease nipple fitted. Make life so much easier !
On 1/5/2018 at 18:50, Kit Car Electronics said:
Yes the returned fuel can be pumped back into the bottom of the tank, without worry of aeration. If the baffles are good and you don't run the tank low then you may be fine for a road car, although I don't know that I believe you'll be driving that cautiously, Gary :laugh:
Mike,
Can you recommend a valve that I could fit inline on the fuel tank breather pipe?
Not sure what you mean, Gary- do you mean a rollover valve, or some way to tee a return into the breather hose without it squirting out the top?
11 hours ago, Gary (KugaWestie) - North Oxfordshire AO said:
Mike,
On the Westfield fuel tank we have the red breather valve on the top of the tanks
On the the top of the Cobra tank I have a 10mm diameter pipe welded on that I want to utilise as a breather by fitting a bit of rubber fuel pipe, then a breather valve, then a bit more rubber pipe.
Does that make sense?
If it helps get give more results,  what you're really looking for is a roll over protection valve
That helps reduce the cost!
http://www.ebay.co.uk/itm/One-Way-Fuel-Non-Return-Check-Valve-6Mm-8Mm-10Mm-Petrol-And-Diesel-Oil/253227337036?ssPageName=STRK%3AMEBIDX%3AIT&var=552339844193&_trksid=p2055119.m1438.l2649
19 minutes ago, Gary (KugaWestie) - North Oxfordshire AO said:
I'd always worry about an important item being 'too' cheap though. Saying that, the WSC one on my tank still cant stop fast take offs and dowses everything in fuel :rolleyes:
That’s not a breather valve, it’s a one way anti-siphon valve. It may work how you want, but you’d need to experiment, as that’s not what it was designed for.
The reason those other valves are so much more, is that they’re proper breather valves. A breather valve needs to allow two way air flow, but not let fuel out. Otherwise the tank will either presurise or suffer from vacuum related problems.
Yes it did appear to be too cheap!
FWIW, the pukka breather valves do seem to be mainly around the same price.
I just happened to save this recommendation from one of the times these have been discussed before.
https://www.merlinmotorsport.co.uk/p/newton-inline-breather-vent-valve-5-16-8mm-push-on-m-tpv8
