Cobra 427 Build
It's off. It's all about having the right tool for the job
Thanks to @CL290005 for the loan of the bearing puller :yes:
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
9 hours ago, Gary (KugaWestie) - North Oxfordshire AO said:
The next challenge is to remove the bearing and race that are stuck on the hub
I think the bigger challenge is explaining to the wife about removing bearings on the bed spread :d
I purchased a new vice which came today, so I fixed it to the bench. It was to replace the Amazon cheapo cast iron that broke in less than a week!
Broken next to new
Next to my cordless drill, gives you and idea of size
It is a bit of a beast :d
Next lot of painting preparation is underway, half shafts, hubs and rear wishbones
On 11/10/2017 at 08:39, Gary (KugaWestie) - North Oxfordshire AO said:
Fuel injection plenum, manifold, loom, sensors, injectors etc arrived today
After doing some research over the last couple of months which came to a conclusion at Autosport International, I will not be using this plenum and set up.
I am still going fuel injection but using a different set up - all will be revealed soon!
@bollockybill - Is this of any use to you before I put it on EBay?
A bit more painting tonight. Rear wishbones this time
Hi Gary,
Would be interested in the throttle linkage, think I have everything else.
John.
I know :p
When I collected the kit, the front dampers and springs were seperate
Sometime last week I was having a bit of a tidy up and thought "I might as well put those springs onto the dampers".
So when I extended the damper and tried to put the spring on I realised why they were not on, the springs were longer than the damper when extended by around an inch or so. I had no way or facility to compress them to get them on, and was not sure if they should be compressed anyway.
BUT WHAT A GREAT CLUB WE ARE!
A pm exchange with @DamperMan confirmed that preload on the springs happens a lot. He very kindly offered to fit the springs for me, which he has done and I collected them tonight
Many thanks Tony @DamperMan:yes:, very much appreciated
5 minutes ago, bollockybill said:
Hi Gary,
John.
Hi John,
I am looking to unload it all in one go really.
Drop me a pm if you like
6 minutes ago, CL290005 said:
I know :p
Sssshh, or I will have to kill you :laugh:
Pm'd.
2 minutes ago, bollockybill said:
Pm'd.
replied
Have to ask how the hell did you break the vice?
Gary,
I have a rear entry plenum if that’s any use to you.
John.
