I want to install a small fuel tank for hill climbs and sprints, how many litres should it hold?
Richard it depends a bit on how thirsty your engine is. I have had my tanks fabricated and they hold around 5 to 6 litres.
I think the tank for my old sprint car (Duratec 2.0 ltr.) was about 10ltrs.
Of course I've no idea how much fuel it consumes....should have measured it!
But it's a 2.3 Duratec so it must be a lot. I certainly wouldn't use 20 litres at 2 days at Anglesey, so I think 10 litres would be enough for a day without the incessant topping up that some folk do.
Top tip: Use a 2 gallon dry sump tank as your fuel tank. Nice and tall to naturally limit surge, plus baffled to help prevent surge even further in case you run pretty low because you get multiple re-runs etc.
2 gallon is perfect for westfield
A & H Brass will make a tank to meet your own design requirements. Mine is an adaption of one of there round tanks with mounting brackets in the required places and the flow and return connections positioned in the optimum places to make connections to the fuel pump and return easy!
One other item to remember is the position of the filler cap which if it on the top of the tank is best positioned to the front of the tank to assist easy filling.
Hope this helps Glutey
