Rob Waldron Posted November 17, 2022 Posted November 17, 2022 Is there any rubberised paint or liners owners use to give a bit of protection to their mudguards underneath. Quote
jeff oakley Posted November 18, 2022 Posted November 18, 2022 I use this product from CBS. However, unless you put very heavy coats on a stone will still cause a star crack https://www.carbuilder.com/uk/wunderseal-underbody-sealer 2 Quote
corsechris Posted November 18, 2022 Posted November 18, 2022 Another vote for 'Wunderseal" and yes indeed, you do need to lay it on very thick then stipple it to create a really rough 3D textured surface for maximum protection. It over-paints pretty well too if need be. Expect to dispose of any brushes you use to apply it! It dries very quickly when applying it so be warned - you can't hang about. Rear arches in particular had lots of pretty bad star cracks after 20 years so when we had the car painted, I put a thick layer of Wunderseal under all the arches. No new damage seen in the last 10 years. I had a spare unopened tin after doing the Westy in 2011 and unsurprisingly it had gone off a bit over the 10 years in between. I rescued it with some cellulose thinners. Added a bit more every so often and eventually it got soaked up to the point I was able to start stirring it. Got it back to full usable state and applied it to all the arches of the Midlana. 2 Quote
BobMet Posted November 18, 2022 Posted November 18, 2022 I used Dinitrol 449. I've written it up in my build diary here and on some subsequent pages. 3000 miles so far with no issues on the rear arches so not a lengthy test yet. 1 Quote
Rob Waldron Posted November 18, 2022 Author Posted November 18, 2022 5 hours ago, jeff oakley said: I use this product from CBS. However, unless you put very heavy coats on a stone will still cause a star crack https://www.carbuilder.com/uk/wunderseal-underbody-sealer Thanks for the tip, how much did you use. I was mainly for now going to do the four wheel arches but quite like the idea of the added protection underneath. Quote
Davemk1 Posted November 18, 2022 Posted November 18, 2022 I have use this brush on "Herculiner" truck bed liner on the underside of my fiberglass and carbon fenders (wings, mudguards) with great success. I've used 3 coats on my carbon front fenders and even with my super sticky slicks throwing up every stone on the planet I've not seen any cracks or damage from underneath. The rubberized nature of the stuff also reduces the noise from rocks being thrown up at the fenders. I nice side effect. dave ttps://www.acehardware.com/departments/paint-and-supplies/specialty-paints/rubberized-coatings/8105165?store=15460&gclid=Cj0KCQiA99ybBhD9ARIsALvZavVR2upRgbD8smM6CULn9SrArLd86iVpmcEpPW4wi0sOcvXbL-hBLSEaAmcHEALw_wcB&gclsrc=aw.ds 1 Quote
Steve20 Posted November 18, 2022 Posted November 18, 2022 CBS only do one size of tin 1kg, ample for all 4 arches.... Quote
DanM Posted November 18, 2022 Posted November 18, 2022 3 hours ago, Davemk1 said: I have use this brush on "Herculiner" truck bed liner I have heard good things about "Herculiner" on some of the other kit car forums and also Duplicolor Bed Armor. Apparently, Bed Armor is more user friendly as it cleans up with soap & water whereas Herculiner requires Xylene...so I hear! Quote
jeff oakley Posted November 18, 2022 Posted November 18, 2022 4 hours ago, Rob Waldron said: Thanks for the tip, how much did you use. I was mainly for now going to do the four wheel arches but quite like the idea of the added protection underneath. Just the one litre tin, but just did the front wings and under the rear wheel arch 1 Quote
