Suitable heater and controls for zetec engine
Just check weights and see how much it is, save the money and go buy some thermals instead.
Everything for the right application ! - track westfield no windscreen, washer,heater... no passanger ;) road one - all that, so 1,5 kg makes not much difference . And its hard to keep proper levels of adrenaline and happy passanger in the same time :) and if this passanger is my Wife well ...  lets say just ordered washer fluid bag :)and found some heaters, just not sure what output power is ok for Westfield ?
Found this one that You @Dave Eastwood (Gadgetman) - Club Chairman have showed on pictures above - Sirocco Minox II 400 , they say it has 5kW output, also found little smaller but 3kW, not sure if this will be enough. I have no cockpit cover / hood  (read that with MSA rollbar is only partial hood possible to install, will think about it in future,  anyway Heater is intended mostly to heat foots, mayyybe in future demist if I will be brave enough to drive in wet . Thought maybe will manage to install it  before salt on the roads this year so need to choose power and order quick!
