SOLD 2007 SeiW 1.8 Zetec Speedsport
Hi all,
      I wasn't intending to sell my car but life has a habit of throwing you a curve ball! To quote Boris 'Them's the breaks'!
I'll detail the spec below but wanted to be straight with the main issue. The engine has developed a knock, I am not sure exactly what the issue is but it's definitely internal and seems to be on cylinder one/two. It only happens when hot and under load. Oil pressure is good and it is like a sewing machine on start up and idling.
I just don't have the time to sort it out, family life and work have taken priority.
It's a simple winter project for someone with time.
I bought the car in August last year and intended to keep it.
(I have used a lot of the info from the previous advert so it will read similarly
First registered in 2007 on an age related '07' plate.
MOT until 1st August 2023
Things I have done:
•Repaired Speedo display
•New alternator (not reconditioned)
•Cambelt and water pump replaced
•Re-powder coated the windscreen  uprights, front grill and hood frame.
•Exhaust repacked and converted to be re-packable
•New air filter.
Previous owner(s) work:
Recent OMEX 600 ECU and racing loom. Every sensor was also changed, throttle bodies balanced and the car underwent a full Dyno and on road remap and setup producing 148bhp at 7k and 122lbft at 5.5k.
Wide track front wishbones purchased from the factory, along with new springs and Protech dampers all round.
New front alloy uprights from Westfield were also added, completing the front suspension upgrade.
Headlight shells have been replaced, along with swapping the lenses for clear glass rather than the patterned factory ones.  These, in conjunction with brighter bulbs mean the headlights are now useable!
The standard Ford thermostat cracked, so this was replaced with a Raceline water rail, and all hoses replaced with silicone.
The car comes with a file full of history which tracks it from the original order through to present day.
Crate 1800 Silvertop on Jenvey ITB's
Omex 600 ECU
Raceline Water Rail
150bhp & 122lbft
MT75 gearbox
Limited Slip Diff
Wide track front end
New alloy uprights
15" lightweight alloys with Toyo R1R's
Heater
Full weather gear
Perspex side screens
The pictures are from the previous advert, it still looks the same but as we're currently still in a hosepipe ban I haven't been able to wash it and get and recent pics.
I will also include the car cover. This is was ~£180
Car is located in Kent, Maidstone
Price:  £8500
Thanks for looking
07843 432532
alecomatthews@msn.com
Would you sell all weather gear?
On its own? I don't want to start selling parts from the car
You can have it for £8500 and get a free car!
  • Haha 5
  • Aleco changed the title to SOLD 2007 SeiW 1.8 Zetec Speedsport
