RX8 Gearbox Concentric Slave Conversion Kit
Concentric slave conversion kit for the RX8 5spd 'box. It allows use of remote bleed slave cylinder, instead of the external one which often fouls transmission tunnels.
The kit includes CNC aluminium billet mount, OEM quality slave cylinder with bleed port, all fasteners, and assortment of shims to adjust clutch height (un-shimmed maximum is ~70mm, allowing for ~7mm retracted travel for clutch wear - this is WITHOUT any engine adaptor plate fitted).
It positions the slave cylinder so the bleed and supply hose can be easily accessed and routed through the existing opening in the bellhousing.  The remote bleed pipe can also be swapped with a hose if preferred.
Requires supply line with M10x1.0 fitting.
£150 shipped within UK
