Full set of westfield shocks and springs..SOLD
Full set of westfield shocks. Done less than 1000miles. Front springs are brand new…
Fronts - 12.5 inch open length, 300lb springs.
Rear - 14 inch open length, 195lb springs…
I believe they are AVO, but very good quality shocks in very good condition.
Free postage……SOLD.
Will these be suitable for all Westfield's or just specific models?
They came off an seiw…what have you got?.
Mazda SDV
1 hour ago, Meel said:
Mazda SDV
Honestly don’t know about the SDV….you would have to get a jack under the front to get the wish bones level then measure distance between mount points…if it’s around 11 in, then they should be fine…but do check.
Ah Mazda sdv needs longer fronts as the wishbones are different to std track seiw.
rears are the same but the fronts need to be 14” open / 300lb
i had std ones and even with the springs screwed right up had poor ground clearance, changed to 14” and alls good
hth and sorry for posting on your advert @Jenko
good luck with the sale
Ah thanks gents, i'll keep my eyes open for some ones that'll fit the SDV. Should've been in my second kit from Westfield but..... 😥
That’s fine…thanks for info, wouldn’t want them to go to a car they don’t fit 👍👍
£250 posted before they go on eBay….
I have an SEW, I wonder if the rears would be correct? Can you let me know the open eye to eye measurement please.
Hi….open length is 14 inches, and 12.5 inches….someone from market place has said they want them, but if it falls though I will let you know…
  • Jenko changed the title to Full set of westfield shocks and springs..SOLD
Shocks now sold…
