Mark 1 Posted August 21, 2022 Posted August 21, 2022 Has anyone got one of these bushes in there spare parts collection, pretty sure it allegro column, dimensions in pic… tia Mark
Ian Kinder (Bagpuss) - Joint Peak District AO Posted August 22, 2022 Posted August 22, 2022 @Paul Aspden (MoFast) is this something you could help Jason stock on Mofast?
Chris Broster Posted August 22, 2022 Posted August 22, 2022 This is the one i ordered (x2 of) whe i fitted the Go-race upper column. It needed a slight sand down externally to fit but really easy and no rattle/vibe now. They do a full range of sizes so best measure inner housing dia and column dia first as Go-Race is smaller. 1 1
Ian Kinder (Bagpuss) - Joint Peak District AO Posted August 22, 2022 Posted August 22, 2022 @Mark Redpath - WSCC Membership Secretary don't ask me how I know, but which ever type you buy, make sure you use a long rod to tap out both your old ones from the opposite end! Don't push the old ones in further and you won't get the inner column back in.
Mark 1 Posted August 22, 2022 Author Posted August 22, 2022 Yes thanks Ian, been doing some research, but the actual supply of these things were exclusive to Westfield, ie push in and forget, other bushes need fettling in some shape or form ….
